Renderman error in houdini
ISUther
Hello,
I downloaded and installed renderman for Houdini 16.5.268
Installed RenderMan-Installer 21.5.0
I also changed Houdini env file in:
C:\Users\Tann\Documents\houdini16.5
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
RMANTREE="/C:\Program Files\Pixar\RenderManProServer-21.5"
PATH="$PATH:$RMANTREE/bin"
C:\Program Files\Pixar\RenderManProServer-21.5 is where is renderman bin located.
When i start Houdini i see RenderMan RIS tab and also render man lights etc
When i click on RIS ROP it will create ris1 node in to "Out" path in houdini
I have set up basic camera and renderman light but when i click on "Render to Mplay" i get an error:
CreateProcess failed for 'prman'
  • 1 year later...
