kev2 Posted November 13, 2017 Share Posted November 13, 2017 I have a simple curved tube open at the top and closed at the bottom with 3 fluid sources inside (see image below). They emit and the fluid travels nicely inside the curved tube. However, it doesn't collect at the bottom of the tube. It also doesn't appear to be leaking or near the volume boundary (so that's not killing the particles either). Hip file attached. Much appreciated if anyone has time to check it out. workbench.hiplc Quote Link to comment Share on other sites More sharing options...
jinguang huang Posted November 14, 2017 Share Posted November 14, 2017 I checked your hip file. You need to make your collision geo with thickness. And for flip or pyro it is better to make enough thickness in order to get a correct collision. Because sometimes when the speed of the sim is too high, it may go through the collision geo. I have attached the hip file. workbench_2.hiplc 1 Quote Link to comment Share on other sites More sharing options...
kev2 Posted November 15, 2017 Author Share Posted November 15, 2017 On 11/13/2017 at 4:50 PM, jinguang huang said: I checked your hip file. You need to make your collision geo with thickness. And for flip or pyro it is better to make enough thickness in order to get a correct collision. Because sometimes when the speed of the sim is too high, it may go through the collision geo. I have attached the hip file. Thanks Jinguang, much appreciated. Quote Link to comment Share on other sites More sharing options...
