Damping or constraining movement in just 1 axis on DOP (bullet solver)
gemrg
So i have this sim and i would like to dampen or even remove the movement in the Y axis since it makes the concrete look light and weightless. I was trying geometry wrangle and anchor nodes, (not really sure how to use either),  i wonder if there is a place where i can simply put a simple VEX line like @v.y = @v.y*0.25 or something similar. Can someone point me in the right direction on where can i do that and where should i plug such node in case there is a way.
untitled.mov
here is the Dopnet right now
