Understanding Ray VEX
logix1390
Hello,
I am in the middle of doing a procedural modeling tutorial:
http://lesterbanks.com/2017/03/procedural-modeling-houdini/
He creates a curve and manually rays it to the terrain using vex .
The code is as follows:  (the curve is in the first input and the terrain mesh is in the second input)
vector rayD = {0,-100,0};
vector hittP, hitUVW;
i@hitPrim = intersect(1, @P, rayD, hittP, hitUVW);
@P = hittP;
This works perfectly
Now I am trying to understand what is going on here exactly and how Houdini is solving this .
I searched for the intersect function in the help and found this:
int intersect(int input, vector orig, vector dir, vector p&, vector uvw&)
I guess what is confusing me is the "vector p&", and "vector uvw&" above and how that related to the vectors he created "vector hittP, hitUVW" .
I am still a beginner in VEX ... If anyone can help me understand this, I would really appreciate it.
I will also attach my scene file for anyone that wants to take a look.
Thank you!
Ray_VEX.hip
for the intersect function, the last 2 parameters are output parameter ;)
you initialize them beforehand and the intersect function will overwrite them, in this case with the position, for "vector &p", where the ray hit (or the "orig" position if it did not hit anything)
"vector uvw&" returns the intrinisic uv of the position on the primitive (i@hitPrim) you could use this together with the primuv() function
basically whenever there is a & in a function param, thats a way the docs try to tell you its an output parameter.
Hope that helps! :)
