setting the dop io preset
newbee
That 'presets' parameter is calling a callback python script.
You could try this:
theGeo = hou.node('/obj/geo1/dopio1')
# Keyword argument needed by the internal invokePresetMenu function
myArgs = {'node': theGeo, 'script_value0': 'pyro'}
# The internal python function called by the presets parameter.
theGeo.hm().invokePresetMenu(myArgs)
Edited by galagast
  • Like 2
  • 2 years later...
You could try this:
Hi.
I did as you told me, but I got an error
error - 'NoneType' object has no attribute 'hdaModule"
I created a new edit in the shelf tool and entered in, but it doesn't run.
Why is that?
Thank you.
