newbee Posted December 4, 2017 Share Posted December 4, 2017 hey guys, here is quick tutorial about vertical alignment of nodes http://www.sidefx.com/docs/houdini/network/layout i really dig the vertical alignment that they talk about in this videos "press A and drag up" any one has an idea how to implement this in python so i select the last node of my network and align nodes vertically Quote Link to comment Share on other sites More sharing options...
E. Ozgur Yilmaz Posted March 16, 2020 Share Posted March 16, 2020 I know it is an old post, but I wanted to reply to this one just for reference: # the key here is to use the Python module that comes with # Houdini itself import nodegraphalign # get the selected node node = hou.selectedNodes()[0] # Get the Network Editor, assuming it is under the cursor # if it is not you can use # # network_editor = None # for pane_tab in hou.ui.paneTabs(): # if isinstance(pane_tab, hou.NetworkEditor): # network_editor = pane_tab # break network_editor = hou.ui.paneTabUnderCursor() nodegraphalign.alignConnected(network_editor, node, None, "down") # up, left, right are the other options # there are also other functions # # nodegraphalign.alignConnected # nodegraphalign.alignItems # nodegraphalign.alignSelected 1 Quote Link to comment Share on other sites More sharing options...
