vertical alignment of nodes
newbee
  • 2 years later...
I know it is an old post, but I wanted to reply to this one just for reference:
# the key here is to use the Python module that comes with
# Houdini itself
import nodegraphalign
# get the selected node
node = hou.selectedNodes()[0]
# Get the Network Editor, assuming it is under the cursor
# if it is not you can use
# network_editor = None
# for pane_tab in hou.ui.paneTabs():
#     if isinstance(pane_tab, hou.NetworkEditor):
#         network_editor = pane_tab
#         break
network_editor = hou.ui.paneTabUnderCursor()
nodegraphalign.alignConnected(network_editor, node, None, "down")
# up, left, right are the other options
# there are also other functions
# nodegraphalign.alignConnected
# nodegraphalign.alignItems
# nodegraphalign.alignSelected
  • Thanks 1
