cdiete20 Posted September 16, 2005 Share Posted September 16, 2005 When i go to use the curve node all of a sudden now it doesnt work correctly anymore. All that I get when I go to draw my curve is transform handles. Anyone know how to fix this? Thanks! Quote Link to comment Share on other sites More sharing options...
cdiete20 Posted September 16, 2005 Author Share Posted September 16, 2005 Im assuming that I must have hit a hotkey and did not realize it or something. That is the only thing that I can think of right now. Quote Link to comment Share on other sites More sharing options...
George Posted September 17, 2005 Share Posted September 17, 2005 Can you still see the curve when you're not trying to edit it? I mean if you hit Esc in the viewport, does the curve show up? Does the Curve node error out? How about when you hit Tab in a fresh viewport and type Curve to start a new curve operation? George. Quote Link to comment Share on other sites More sharing options...
cdiete20 Posted September 18, 2005 Author Share Posted September 18, 2005 well I cant even begin to draw the curve in the first place. The second that I hot enter to begin placing my vertices all I get is a transform handle. Quote Link to comment Share on other sites More sharing options...
edward Posted September 18, 2005 Share Posted September 18, 2005 It sounds like you're not in a SOP viewer at all but at the OBJ level instead. In your viewer, is the background colour of your pane menu green? Maybe you unlinked the panes? Quote Link to comment Share on other sites More sharing options...
cdiete20 Posted September 19, 2005 Author Share Posted September 19, 2005 It sounds like you're not in a SOP viewer at all but at the OBJ level instead. In your viewer, is the background colour of your pane menu green? Maybe you unlinked the panes? 21355[/snapback] You were right, thank you so much! I did change around my windows awhile back and I guess I just forgot to reset them. Thanks again! Quote Link to comment Share on other sites More sharing options...
Jason Posted September 19, 2005 Share Posted September 19, 2005 You were right, thank you so much! I did change around my windows awhile back and I guess I just forgot to reset them. Thanks again! 21365[/snapback] My God, Edward. You must be psychic. Quote Link to comment Share on other sites More sharing options...
