diula Posted September 22, 2005 Share Posted September 22, 2005 Hello, I just downloaded HoudiniNC for the first time and will evaluate the software. I have a couple of questions related to rendering though... 1. Mantra - how good is it actually? I have been working with RMan for quite a while...How does mantra compare in the scanline area? I notice that it has "micropolygon rendering". Is this the same (or similar) to Reyes? Is mantra good with massive datasets - memory consumption and speed wise? 2. Delayed archives - does it have that functionality? I am particularly interested in this one, as the project I intend to do involves rendering a couple hundred detailed tree models in a lansdcape. This was not a problem for rman (in maya/mtor)...Problem is that I will not be able to use rman for this project (it's a personal project) (( Thanks in advance for your answers. Quote Link to comment Share on other sites More sharing options...
Jason Posted September 22, 2005 Share Posted September 22, 2005 Hello,I just downloaded HoudiniNC for the first time and will evaluate the software. I have a couple of questions related to rendering though... 1. Mantra - how good is it actually? I have been working with RMan for quite a while...How does mantra compare in the scanline area? I notice that it has "micropolygon rendering". Is this the same (or similar) to Reyes? Is mantra good with massive datasets - memory consumption and speed wise? 2. Delayed archives - does it have that functionality? I am particularly interested in this one, as the project I intend to do involves rendering a couple hundred detailed tree models in a lansdcape. This was not a problem for rman (in maya/mtor)...Problem is that I will not be able to use rman for this project (it's a personal project) (( Thanks in advance for your answers. 21445[/snapback] Hi there, Personally I am a huge fan of Mantra; I enjoy its functionality and it's quality and speed has taken huge step as of version 8. If you would like to get know the feature set, you can read this: http://www.odforce.net/wiki/index.php/Rendering Read all the Mantra links in there. As for the Delayed reads, yes , Mantra supports that. You can also do point instancing very efficiently - and combine them. If you need guidance, write in! Quote Link to comment Share on other sites More sharing options...
diula Posted September 23, 2005 Author Share Posted September 23, 2005 Thanks Jason, I will invest more time in learning mantra then:))) Quote Link to comment Share on other sites More sharing options...
