mahdi_d Posted December 23, 2017 Share Posted December 23, 2017 hi everyone, i'm trying to do something like having multiple RBD objects with constraints setup through one Single constraints setup withing a DOP .. i am still newbie in houdini and have no idea about the logic behind it.. put me in the right direction .. what is the approach to get this working? what i have done was i copied the nodes in the DOPS including RBD objects, bullet solver, constraint network and wired them back to the original merge that flows to the output and RBDs are there but constraints are not working and there is certainly problems with the names and should not the be solution .. do i have to do the node copies in the geometry level ? .. hope to have made myself clear .. thank you in advance for any help .. Quote Link to comment Share on other sites More sharing options...
markinglevfx Posted December 26, 2017 Share Posted December 26, 2017 (edited) For multiple RBD packed objects, you need to make sure all pieces have a unique name inside the sim. Say I want to use a fractured box and a fractured sphere in the same sim: I fracture a box with voronoi and pack with an assemble node, the name attribute will be piece0, piece1... etc. I do the same with a sphere, but that also gives me piece0, piece1... etc. in the name attribute. Having duplicate name attribute values in the RBD sim will not work as we expect. You'll have to rename the pieces using the sprintf function like so: s@name = sprintf("box_piece%d", @ptnum); From there you can make your constraint networks, and give each object's constraints a unique name e.g 'sphere_constraints' and 'box_constraints'. You can merge the constraint networks in SOPs for a neater DOP network, but it's not necessary. I have attached a file for you multiple_rbds_with_constraints.hipFetching info... Edited December 26, 2017 by markingleukc 1 2 Quote Link to comment Share on other sites More sharing options...
beliveau.maxime Posted December 27, 2017 Share Posted December 27, 2017 Hey Mahdi, I strongly suggest you take a look at Steven Knipping's videos. The first one is free. And the second isn't but it really has all the answers you're looking for if ever you have a few bucks to spend. Cheers! 2 Quote Link to comment Share on other sites More sharing options...
mahdi_d Posted December 27, 2017 Author Share Posted December 27, 2017 On 12/26/2017 at 6:01 PM, markingleukc said: For multiple RBD packed objects, you need to make sure all pieces have a unique name inside the sim. Say I want to use a fractured box and a fractured sphere in the same sim: I fracture a box with voronoi and pack with an assemble node, the name attribute will be piece0, piece1... etc. I do the same with a sphere, but that also gives me piece0, piece1... etc. in the name attribute. Having duplicate name attribute values in the RBD sim will not work as we expect. You'll have to rename the pieces using the sprintf function like so: s@name = sprintf("box_piece%d", @ptnum); From there you can make your constraint networks, and give each object's constraints a unique name e.g 'sphere_constraints' and 'box_constraints'. You can merge the constraint networks in SOPs for a neater DOP network, but it's not necessary. I have attached a file for you multiple_rbds_with_constraints.hipFetching info... Expand thank you so much for great explanation .. Quote Link to comment Share on other sites More sharing options...
kellydesign Posted April 11, 2019 Share Posted April 11, 2019 Hey Mark - just wanted to say thanks for posting your file. I had the same issue and seeing your node network helped me figure out the problem. Quote Link to comment Share on other sites More sharing options...
Kotoff Posted August 5, 2019 Share Posted August 5, 2019 Tried to replicate it in Houdini 17.5. DOP can't recognize any of my constraints, even if I'm giving different names to fractured objects. What I'm doing wrong? multiconsnetwork.hipnc Quote Link to comment Share on other sites More sharing options...
AVTPro Posted April 8, 2021 Share Posted April 8, 2021 Super Thanks Mark for the explanation and the .hip file. It worked perfectly! Quote Link to comment Share on other sites More sharing options...
