link ramp parameters with python
pelos
is there a way that i can link a ramp to another?
like right click copy parameter->paste relative reference
i am doing ramp_parm_1.set(ramp_parm_2) in python,     with python it only link the amount of ponits, but doesnt link the value or position of each point =(
is there a special way to link ramps?
thanks.
link_ramps_python.hipnc
  • 7 months later...
I am reviving this thread because I have the same problem.
I was able to link 2 ramps via an extra Python Node  that does the following:
sourceRamp = hou.parm('/obj/geo/Box1/Ramp')
destinationRamp = hou.parm('/obj/geo/Box2/Ramp')
destinationRamp.set(sourceRamp.eval())
I have to setup quite a few ramp links via Python and I would like to do that as a python expression at the destinationRamp. Just doing rightClick -> Expression -> Edit Expression on the destinationRamp's name and putting in hou.parm('/obj/geo/Box1/Ramp').eval() did not work. Would I also have to setup Python expressions for the destinationsRamp's Positions and Values?
Thank You.
