Orienting copied objects
logix1390
Hello,
So i have a roof and I want to make some wooden pillars on the inside of this roof. My method is to basically copy the pillars to the centroid line of each side of the roof. I know the copy sop looks at the normals for orientation so I made sure my normals are aligned the right way before I copy. However, The copy is still not respecting the orientation of the normals. I have been trying to figure this one out for 2 days now. Im sure im missing something easy here... I will attach some pictures and my scene file to show you what I mean.
Thank you.
pillar_orientation_roof.hip
The copy SOP has a heirarchy of attributes it reads in, orient being the foremost, N and up if orient is not present, etc.  N alone is not enough to define orientation in most cases, usually you pair it with an up vector attribute as well
http://www.sidefx.com/docs/houdini16.0/copy/instanceattrs
You can use a polyframe SOP to generate N and up attribs from curves
pillar_orientation_roof_FIX.hip
