How could I apply forces on certain points of an object
hicz
hi,
I want to apply force on certain points of an object and using point attributes to control the force. I have tried vop force but it only worked at the center of object, and I can not change sampling mode of vop force.
Is it possible to apply forces per point or per primitive in RBD simulation?
thanks
On 2018/1/3 at 12:15 AM, beliveau.maxime said:
Of course it is!
Groups you create in SOPs get pulled in in DOPs. Here's a small example file to get you started :)
example_RBD_forces.hipnc
Thanks for you example. But what I want is not apply force on packed individual objects. I want to apply different forces on a single object, and the forces are dependent on point attributes on the object, for example, forces scaled by Cd attribute.
  • 2 weeks later...
