ronald_a Posted January 2, 2018 Share Posted January 2, 2018 how do I set pscale within a pop stream ? seems if i have several streams, the last one wins (the pscale set on the last stream in the merge). what I want is different pscale values in different streams. Quote Link to comment Share on other sites More sharing options...
Sean-R Posted January 3, 2018 Share Posted January 3, 2018 (edited) Not sure why that doesn't work in the dopnet, but the streams are accessible as groups so you can set the pscale at the SOP level. EDIT: Just checked again and I can set the pscales of separate streams using either the POP wrangle or POP Proximity in a popnet. How are you setting the pscale? Edited January 3, 2018 by Sean-R Quote Link to comment Share on other sites More sharing options...
ronald_a Posted January 3, 2018 Author Share Posted January 3, 2018 ah, I tried via sop solver or geo wrangle. they do not respect streams it seems - make sense now that i think about it. thanks for the help Quote Link to comment Share on other sites More sharing options...
