Render Artifacts With Vop Displacement
vrljc
Hi Jon,
Try turning on Displace Bound for the model Object. The parameter can be found under the Render tab of the object.
The value should be equal or more than the displacement value you're using though sometimes, it could be less. However, you don't want to make the value too big else mantra will take a longer time to render. I usually channel reference the value from the displacement shader & put an abs() function to make the value always positive.
Cheers!
steven
:alien1: If you enable verbose output, you'll get a message from mantra telling you what the maximum displacement it found during the render. But if you're attentive and know the ranges of your displacement vop (the noises all have different ranges, btw) then you can always make a more educated guess as to the limits.
:alien1: :alien1: If you want to enable verbose output under Windows and wonder where the hell the output ends up, try this on the Command parm in the Mantra ROP: mantra -V 4a -o consolenowait
Hope this doesn't harm :ph34r:
Jason
