Ray node scale input
Rence
Hi guys,
I am trying my best to figure this out. I have a ray node and instead of the scale value animating from 0 - 1 and the whole mesh moving at once, I want it to animate from the bottom up.
So I added a point sop and added color ($BBY in the red) then I added a pointvop and in there I extracted the red and set it to a ramp parameter and animated the ramp so the color now fills up from the bottom.
Then I have the ray node, set to Minimum Distance. I want to enter in an expression into the Scale input that I guess tells the ray sop that where there is color, those points should move to the collision primitive.
Is this possible or am I going about this the wrong way?
