[Solved] RBD to FLIP by Johnny Farmfields works modification.
vomthestoryteller
Hello Magicians out there.
I am following up the Johnny Farmfield's tutorial Houdini - RBD to FLIP
Johnny's set-up works fine with nodes but when I try to change the geometry to others, The sopsolver in the RBD_SIM make things won't work.
When I bypass sopsolver, the rigid body sim works fine but Johnny's vex code
@active = (@P.y < 1.25 + (@Frame/150)) ? 1 : 0;
if(@P.y < 0.1){
    removepoint(geoself(), @ptnum);
Is unavailable.
could anyone tell me what is wrong with my nodes?
Thank you in advance!
rbd_to_flip.hiplc
  On 1/19/2018 at 10:31 PM, mine said:
I think it works ok, but your geometry is way higher than the example torus, so the wrangle condition never gets to be true. Try to lower @Frame/150 to @Frame/5 for example
Expand
Hi mine.
I didn't check the object's @P.y data.
I changed "active = (@P.y < 1.25" to my objects' condition and also @Frame/150 to lower.
It worked! Thank you so much!!! :)
  • vomthestoryteller changed the title to [Solved] RBD to FLIP by Johnny Farmfields works modification.
