AntoineSfx Posted January 29, 2018 Share Posted January 29, 2018 Is there a clever way to unroll a planar curve, of course in a progressive way ? The effect I'm trying to achieve is a rug unrolling after an initial impulse , or with the effect of a constant force in a fixed direction. So far, I've tried to stitch curves created to the specifications explicitly (one line + 1 Archimedean spiral) but it's neither very stable nor procedural. This is highly dependent on the parametric equation of the initial curve. I was thinking of doing something like this: once I have the resampled curve as polygon, I could define the whole curve as a n-uple of (vector, angle), angle being the relative angle to the next point. Then flatten the curve by changing all the angles to zero, in a nice ease in / ease out, several points at a time. Quote Link to comment Share on other sites More sharing options...
mestela Posted January 29, 2018 Share Posted January 29, 2018 Quite a few answers come up if you search for 'unroll' here. Several solutions in this thread: http://forums.odforce.net/topic/31600-spiral-unrolling-rolling-animation/?do=findComment&comment=174963 Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted January 29, 2018 Author Share Posted January 29, 2018 Thanks. BTW the search function used by Invision is confusing. I didn't find it for some reason and I almost sent another Hawaii’s missile alert. Quote Link to comment Share on other sites More sharing options...
