selectedNodes are yellow, but what is the "pink" state? (python)
ikoon
Please, if you select node(s) and then click anywhere in the empty area of Network Editor, nodes are deselected, and last selected node gets pink outline. Can I get this pink node's path in the Python? The pink node is not listed in the selectedNodes() but it is still the actual node in the Parameters pane.
Thank you very very much Alexey! Tons of future errors are wiped out :)
Btw I have two Network Editors and this works nicely:
parm_pane = hou.ui.curDesktop().paneTabOfType(hou.paneTabType.Parm)
node = parm_pane.currentNode()
