basic questions- question 1
Najat
Hi this a part of a series for people like me that are true beginners in houdini. Hopefully answering this question will not help me only but the hundreds of people trying to . figure out this software the most clear way possible.
Thanks everyone.
How can I transform the scale of the selection only?
Hey!
There are (at least) two ways:
1. You can type in the primitive numbers into the Group parameter at the top of the transform node.
2. Once you've made your selection you can hit "E", "R" or "T" to create and Edit node. The hotkeys are for Scale, Rotation and Translate respectively.
Hope this helps
