Rounded corners on a flat geometry
PlatinumFishy
I am attempting to model a cassette tape in Houdini. I wanted to start off by doing as much as I can before extruding it so it would be easy to make good topology. The only main part I am missing is the rounded corners. I know I can poly bevel the corner edges AFTER I poly extrude my flat template but is there a way I can round them before the extrusion? Doing it before would make retopologizing easier.
Edit: This is also my first serious attempt to model something (I know houdini isnt meant for modeling per say) so advice on how to improve my topology would also be appreciated.
Edited by PlatinumFishy
could try something like this:
01) get the corners with the Valence preset in groupexpression, call them corners.
02) bevel the corners, you'd expect the group corners to be avail in the dropdown list...but no....bug ? who knows, just type in corners
