Problem with imported "Visualization Geo" from Constraints Network
Ronald Ruiz
Hi! This is what I did: I made a cool sim with wires and constraints, it works all fine but I decided that I wanted those colored polylines that are drawn by the sim for the constraints. So I created another geo node and object merged the "Visualization" geo from the Constraints Network, It worked! but with a little problem, If I scrub through the animation timeline sometimes I get the "static" state of the constraints, this can be solved If I just scrub a little more near the frame that has the problem, sadly it happens again in another frame (randomly) I guess that my trick is a little dirty and Houdini doesn't like it. Is there anyway I can import this visualization geo as seen inside the DOP Network? Here is my file, It's a little messy (weird experimentation) so sorry for that. Just Press Play and you should see the problem.
DynamicWireConstraints_personal.hipnc  Houdini 16.5 NC
Edited by Ronald Ruiz
