Custom parameter - Attribute dropdown list
Did some more searching and i found an older topic here that had what i needed -
Setting the list to Multiple Selection Menu instead of Single i could make a list of the attributes i didnt want with the following vex-code:
s[]@pointattribs = detailintrinsic(0,"pointattributes");
string attriblist = chs("../attribtrans"); //Multiple Selection Menu
string alist[] = split(attriblist);
foreach(string name; alist){
    removevalue(@pointattribs,name);
  • Like 2
General way is to use Python as Menu script:
from itertools import chain
node = hou.pwd()
geo = node.geometry()
attribs = [a.name() for a in geo.pointAttribs()]
return list(chain(*zip(attribs, attribs)))
attributes_menu.hipnc
It is possible to avoid it in many cases. When you promote parameter it will usually pick the menu script (if it exist) from the node. It is not necessary to have such menu on the target node, as you may promote parameter from a different node (example).
  • Thanks 3
Yeah, i use Python in the menu, but i needed the list in vex aswell. And having it pull the attributes from the target node was a bad idea since the attributes i removed also got removed from the list itself.
And the reason i couldnt promote the parameter is because it doesnt exist on the wrangle itself, i could have made a dummy node instead and promoted that.
My menuscript ended up like this:
result = []
geo = hou.pwd().inputs()[0].geometry()
for attr in geo.pointAttribs():
        result.append(attr.name())
return result
