nemesis9309 Posted February 22, 2018 Share Posted February 22, 2018 Hi, Is there a way to hide the contents of my subnet, I want to submit my sim on a remote machine and I do not want its contents to be exposed, is there any way to do this? Thanks Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 23, 2018 Share Posted February 23, 2018 Houdini will still be aware of it, but you can visually hide nodes. The quick way, is to RMB > Flags > Hide Node, and to Unhide Nodes in the network pane go to Edit > Unhide all (Shift+E). You can set the hide function to a hotkey if you want, which used to be the case. This is generally associated in VOPs, with the little nub parameter inputs. You may be better making an HDA, and black boxing the content, this would be a lot safer in that regard. 1 Quote Link to comment Share on other sites More sharing options...
nemesis9309 Posted February 26, 2018 Author Share Posted February 26, 2018 Can you tell me where I can do that? I'm unable to find an option in the Create Digital Asset properties Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 26, 2018 Share Posted February 26, 2018 If you are doing the black box option in 16.5 go to the main menu stowbar, Assets > Create Black Box Asset from Selection... It is best to create and version control your HDA normally, and then when you are ready select your HDA and convert it. Once you black box the asset you can not undo that specific file/hda. Quote Link to comment Share on other sites More sharing options...
nemesis9309 Posted February 28, 2018 Author Share Posted February 28, 2018 Thanks a lot!! i dont know why I couldnt see that Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 28, 2018 Share Posted February 28, 2018 lol, I have those days way too often, lol. Quote Link to comment Share on other sites More sharing options...
