henderthing Posted October 11, 2005 Share Posted October 11, 2005 I'm fairly new to L-systems, (and this forum) and am running into a few difficulties. I notice that $(x,y,z) will allow me to override the orientation of the turtle, which is great--as it's the only vector-based control over orientation I've seen so far. But I want to calculate that vector based on any number of aspects of surrounding geometry. I tried doing something like this: $((point("../point1",(nearpoint("../point1",x,y,z)),"N",0)),(point("../point1",(nearpoint("../point1",x,y,z)),"N",1)),(point("../point1",(nearpoint("../point1",x,y,z)),"N",2))) for instance, as a crude test to orient the turtle in the direction of the nearest point of the sop "point1"'s normal------Only to discover after it failed that there are a very limited number of functions available to expressions within L-systems. Of course "point" and "nearpoint" are not among them. Does anyone know of other techniques for getting info from other sops into the L-system? in(x,y,z) isn't gonna cut it, I'm afraid. If this limitation is as insurmountable as it appears, I'm going to have to investigate using POPs to do what you'd think an Lsys is approprate for. Any clues? Thanks -m Quote Link to comment Share on other sites More sharing options...
peliosis Posted October 15, 2005 Share Posted October 15, 2005 Are you going to use such expression in l-system rules? Try using the expression in custom variables to obtain vector components and put variables into your rules. Quote Link to comment Share on other sites More sharing options...
henderthing Posted October 17, 2005 Author Share Posted October 17, 2005 Cool--thanks for your reply. I didn't think that the x,y,z stuff would get evaluated properly at the parameter level (for each step of the L-sys)...doh. Of course now, I will have used up all three user variables for a single vector's worth of information. Is there a way to add more user variables? In general--it's seeming pretty tricky to get Lsys to behave in a way that relates to other geometry in the scene. I've been looking into procedurally building curves, or copy-stamping curves instead. But trying to keep my options open--for a couple more days anyway... -m Are you going to use such expression in l-system rules?Try using the expression in custom variables to obtain vector components and put variables into your rules. 21891[/snapback] Quote Link to comment Share on other sites More sharing options...
deecue Posted October 17, 2005 Share Posted October 17, 2005 Is there a way to add more user variables? @ ____________________________________ | [Geometry] [Tube] [ Values ] [Funcs] [Rules]| |.......................................................................| |Number of Variables ___ [more] [less] [clear]| ____________________________________ Quote Link to comment Share on other sites More sharing options...
peliosis Posted October 17, 2005 Share Posted October 17, 2005 To be honest the count of variables you can use with l-systems is pretty small, check this thread and search for l-system on sesi forum: my sesi forum l-sys question About controlability, note that basic l-system definition does not allow to create absolutely predictable and controlable shapes. Their power lies in easy creation of complex semi random structures. Houdini expands l-system possibilities, but there still are some limitations. With the method we discussed up there, you can create some kind of control rig (the easiest I tried uses nulls to control directions), but you could achieve great and easy effects mixing lsystem with other geometry, eg. curves for trunk and main branches and l sys for the mess of branches. You can grow the curve using carve sop etc. If you already havent went through it:) : Algorithmic botany cheers Quote Link to comment Share on other sites More sharing options...
henderthing Posted October 17, 2005 Author Share Posted October 17, 2005 Thans for all the info... Turns out my initial assumptions were correct, sadly... If I use x,y,z in an expression for a variable, that variable is only evaluated once for the whole system. Not at each step, with its new x,y,z, which makes sense. So I can get info about an external point into those variables, and make some calculations within the rules, using current x,y,z--but it seems I'll never be able to do anything like find the point on another piece of geometry that is nearest to the current step of the turtle. That's where I'm really stumped. The variable thing seems to be most valuable for copy stamping parameters onto Lsystem copies. Of course--I didn't even SEE the interface was there for adding user variables (silly) -- so it's anyone's guess what other obvious things I could be missing here... Thanks again -m To be honest the count of variables you can use with l-systems is pretty small, check this thread and search for l-system on sesi forum:my sesi forum l-sys question About controlability, note that basic l-system definition does not allow to create absolutely predictable and controlable shapes. Their power lies in easy creation of complex semi random structures. Houdini expands l-system possibilities, but there still are some limitations. With the method we discussed up there, you can create some kind of control rig (the easiest I tried uses nulls to control directions), but you could achieve great and easy effects mixing lsystem with other geometry, eg. curves for trunk and main branches and l sys for the mess of branches. You can grow the curve using carve sop etc. If you already havent went through it:) : Algorithmic botany cheers 21920[/snapback] Quote Link to comment Share on other sites More sharing options...
peliosis Posted October 18, 2005 Share Posted October 18, 2005 but it seems I'll never be able to do anything like find the point on another piece of geometry that is nearest to the current step of the turtle. 21925[/snapback] Why? You'd like the effect of lsystem creeping on some geo? So that main branch would creep and lateral, smaller ones could be randomly spread? Or l system that fills some space within geometry. You could put trunk points into a group and the last point in that group should be somewhere close to current generation/turtle position. Now feed the nearpoint expression with that point and you should be done. You can try metatest input but better write rules carefully, otherwise you'd get stuck with very dense geometry, you could use context for that. You can use almost any number of variables since you can use custom parameters (connected to generations/turtle pos.) to describe them. I really haven't test these methods but they are the second thing that comes to my mind (right after simplyfying things with combinations mentioned up there:)) and should work. Maybe more experienced users could shed some light, but I believe l-systems are not being used to the extents by anybody. They ARE very powerful. You really should try l-sys copied on carved curve followed by polywire sop, it's beautiful and easy. Quote Link to comment Share on other sites More sharing options...
henderthing Posted October 20, 2005 Author Share Posted October 20, 2005 Why? Well--I'd like to be able to actually have the Lsys begin to bend before it gets to outside geometry. There are a number of ways to deform existing Lsys geometry based on the point attributes, but non of them would be quite as nice as having the kind of control that I imagined would be possible before I got into this. (mainly--step by step information about other points on other geometry in order to "point" each branch in a desired direction as it grows.) I haven't messed with groups, and that idea sounds interesting as a way of getting information about branch position, after the fact. I presume that you are talking about using an expression somewhere outside (after) the Lsys, within another node. Creeping a 2d Lsystem along a surface with the creep sop, then growing other Lsystems inward is an option, but would be less desirable aesthetically. I have used the carve sop with copy stamping, and it's nice, but the other problems remain. Thank you for the ideas--but I think that since I don't need to animate this stuff, but rather just need a good model with some meaningful point attributes, I am going to use a particle system to draw my curves. Not quite as elegant, but the control is most definately there. I agree that there don't seem to be many people out there really taking Lsystems in Houdini to the nth degree...Perhaps another good reason for me to go with particles. Thanks again for your insights. -m Why? You'd like the effect of lsystem creeping on some geo? So that main branch would creep and lateral, smaller ones could be randomly spread? Or l system that fills some space within geometry. You could put trunk points into a group and the last point in that group should be somewhere close to current generation/turtle position. Now feed the nearpoint expression with that point and you should be done. You can try metatest input but better write rules carefully, otherwise you'd get stuck with very dense geometry, you could use context for that. You can use almost any number of variables since you can use custom parameters (connected to generations/turtle pos.) to describe them. I really haven't test these methods but they are the second thing that comes to my mind (right after simplyfying things with combinations mentioned up there:)) and should work. Maybe more experienced users could shed some light, but I believe l-systems are not being used to the extents by anybody. They ARE very powerful. You really should try l-sys copied on carved curve followed by polywire sop, it's beautiful and easy. 21965[/snapback] Quote Link to comment Share on other sites More sharing options...
meshsmooth Posted October 26, 2005 Share Posted October 26, 2005 in the Houdini L-system help pages there is an example of L-systems interacting with DOPs to make an animation that looks like someone plucking a piece of fruit from the branch of a flexible tree, the tree bends and then springs back as the fruit snaps off. i don't understand how they are inputting the control but it is impressive. Quote Link to comment Share on other sites More sharing options...
aracid Posted October 28, 2005 Share Posted October 28, 2005 in the Houdini L-system help pages there is an example of L-systems interacting with DOPs to make an animation that looks like someone plucking a piece of fruit from the branch of a flexible tree, the tree bends and then springs back as the fruit snaps off. i don't understand how they are inputting the control but it is impressive. 22167[/snapback] hey meshsmooth it is impressive and as far as i can tell they just have a wire constraint thats been animated via a expression, basic turn on turn off expression. its pretty neat aracid Quote Link to comment Share on other sites More sharing options...
