create group with wrangle from @class using "iteration" in foreach
I'm trying to create groups with a wrangle from @class attrib after a connectivity sop, using "iteration" attrib in a foreach loop.
f@group_`"detail("../foreach_begin1_metadata1/", "iteration", 0)"` = @class;
I was thinking the backticks and quotes should resolve to the iteration number as a string. then concatenate it to the f@group_ and that equal to class number. However i think the iteration and class atribs are integer values and the f@group has to be a float?
confused...
If you specifically want to do it inside a for each, this will work (metadata must be plugged into second input):
setpointgroup(0, sprintf("group_%i", int(detail(1, "iteration", 0))), @ptnum, 1, "set");
*edit : presuming you're using class as your piece attribute
Edited by j00ey
sprintf thats right. thank you.
