CinnamonMetal Posted March 12, 2018 Share Posted March 12, 2018 (edited) This code is all within a POPNet Node (Vex Expressions) int tArray[] = {}; // Is the {} required for a variable ? for(int i=0;i<500;i++){ append(tArray,i); The above code is part of a larger block of code; but it doesn't write to an array, as in; there is no array attribute visible within the geo spreadsheet ? As well, can't I write to an array as such ? i[]@pntCol; for(int i=0;i<500;i++){ append(i[]@pntCol,i); Edited March 12, 2018 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
