snow effects with POP grains
UpyopyoSky
hi, I try to make snow effect with grain solver, started from wet sand shell, wetness=1, and changed clump stiffness to 100.
After tweaking around parameters, I got 3 main problems.
1 – how to add friction to static object? I set friction 10, bounce 0 , but particle is still sliding a lot.
2 – When dynamic object collide grain particle, it pushes away too much, but should not influence to surrounding particles. I think constrain pushes away in order to keep space between particles.
3 – particle motion is kind of springy or bouncy. Snow should damp velocity immediately.
I guess I need to figure out how to control compression or density of particles by grain's internal constraint?!
If anyone knows solutions, it would be great, thanks!
grainSnow_v01.hip
  • 5 months later...
2 minutes ago, trunksdavid said:
I've tried a lot to tackle this and eventually had to manually give bounce to the grains. I'm not sure if the grain particles accept bounce. Maybe a solution or new feature can be expected in the future. I'm also new to this. If someone can give a solution, Please do.
