pjackson Posted April 3, 2018 Share Posted April 3, 2018 Hi, Unreal engine has a standard skeletal mesh they use for the default car rig- its set up a certain way with a set hierarchy and joints facing a certain way, Im trying to make it so i can import-modify-export this car rig through houdini using fbx. Ive managed to import it and then export it again getting the same thing, but im having trouble changing the rig in houdini before exporting.Im not very experienced riggng in houdini. Ive attached my hip file, this exports to unreal fine and works with their car physics component, but... 1- I dont know how to change the bind pose on the rig. I want to move the wheels forward or back in houdini to fit another car., i move the bone and capturedeform moves the wheel, but when i export the fbx the wheel goes back to its original position, it seems to be exporting the bind pose. How can i change the bind pose? 2. I want to attach new geometry to the rig but im unable to, the capture regions for the wheels dont seem to work? I probably dont even want to use capture regions- i want to do a rigid bind based on groups, im unsure how to do that. How can I bind new geometry to the rig? If i could make it work i could make a super useful hda to get cars into unreal. any help/suggestions would be awesome! unrealcar_01.hiplc Quote Link to comment Share on other sites More sharing options...
