Redshift - Changing topology Motion Blur - SOLVED (hip)
Motion Blur changing topology issue.
Hi guys! I am having an issue with Houdini + Redshift.
I have a geometry moving and im using a boolean to desintegrate it art directed.
The thing is, since im using a boolean, there is a lot of point changing on the mesh so redshift is not able to compute the motion blur because the changing topology, i have this message when i hover the redshift render rop:
Any tip on how to solve motion blur on changing topologies? I already have a trail sop to compute velocity on my node tree. Got the latest houdini indie and redshift.
HIP attached.
Thanks!!
mberror.hiplc
Edited by macj89
Solved by Peter Sanitra @ Redshift Render community facebook group.
Uploading the updated hip file.
So:
1. you have to compute the velocity of points before the boolean, then use a atribute transfer to transfer the velocity from that preboolean to the new boolean geo.
2. go to redshift per object parameters (OBJ level) - Settings - Render and activate Deformation Blur From Velocity Attribute , so you force redshift to compute the motion from your velocity atribute from points.
Done! :)
I hope my full morning investigation will be usefull for you guys! Keep growing!
mberror_solved.hiplc
  • Like 6
  • Thanks 3
