Number Of Points In A Group
Lukich
It'd work, but I need to write an expression properly - and all the expressions I found so far that deal with an attribute of a group work in SOPs, not in POPs.
22110[/snapback]
Would it work if you referenced the owner POP Network SOP? So if you had a geometry object called /obj/model and in it you had a POP Network called popnet1, then you can perhaps do a:
pointlist("/obj/model/popnet1", "group1")
George.
I wish, man. Unfortunately, the pointlist doesn't work in POPs, only in SOPs. I found the answer in a different thread, $NGRP in the attribute POP seems to work. Thanks!
Luka
George.
22133[/snapback]
