Need help with simple string manipulation
PlatinumFishy
Trying to access a dynamically generated parameter from my control node and eventually put it into an array. I just do not  understand why using the path variable is any different from just reading the string directly.
here it is in text form btw
int maxi = 2;
for(int i = 1; i < maxi; i++){
string path = sprintf("../control/parm%g", i);
s@path = path;
//works^
float param = `chs("../control/parm1")`;
f@param = param;
//works^
float value = `chs(path)`;
f@value = value;
//doesnt work^
Edit : Ive added a simple project file
vex calling.hiplcFetching info...
Edit2: Okay I figured It out, I need to get rid of the back quotes encasing the chf() in order for it to work properly. This probably has to do with me copying the parameter and pasting relative reference in order to get the syntax.
Edited by PlatinumFishy
  On 4/6/2018 at 8:50 PM, davpe said:
the problem is that you cant have a string in a float attribute. floats can only be numbers.
Expand
What do you mean? I am using the path variable to store the reference nor the actual value. When getting the value for the param variable I also used a string within the chs() and it worked.
  On 4/6/2018 at 9:43 PM, Jesper Rahlff said:
your value variable is cast as a float, but you assign it the value of a string by using `chs()`
Expand
Again, am I not doing the same thing for the param variable?
this works: float param = `chs("../control/parm1")`;
That is also using the chs() and it reads into a float.
Edit: Okay I figured It out, I need to get rid of the back quotes encasing the chf() in order for it to work properly. This probably has to do with me copying the parameter and pasting relative reference in order to get the syntax.
