itsssayuuu Posted April 7, 2018 Share Posted April 7, 2018 Hello guys, Well i am working on an ocean scene having foam particles over it, I need to render the scene but everytime i put the scene on render it starts using 100% CPU Usage and crashes. Plz tell me how to down sample my render i have 200 frames and not one is getting render. All the render settings are on default and rendering via physically based rendering. PC Configuration- I7 6700 PROCESSOR AMD 2 GB RADEON R7 DDR5 GRAPHIC CARD 16 GB RAM Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted April 7, 2018 Share Posted April 7, 2018 More than CPU usage, how is your RAM usage ? How many millions particles do you have ? If you really can’t solve your problem, then you should try to render using a cloud render farm, like MarketGrid... less limitation (much more RAM per core than your setup), and they offer a few hours of computing to test the service, and your computer is free while the cloud render your frames for you. Addicting :-) Quote Link to comment Share on other sites More sharing options...
itsssayuuu Posted April 7, 2018 Author Share Posted April 7, 2018 On 4/7/2018 at 3:21 PM, StepbyStepVFX said: More than CPU usage, how is your RAM usage ? How many millions particles do you have ? If you really can’t solve your problem, then you should try to render using a cloud render farm, like MarketGrid... less limitation (much more RAM per core than your setup), and they offer a few hours of computing to test the service, and your computer is free while the cloud render your frames for you. Addicting :-) Expand Umm.. Well its using 13.8 something out of 16gb. And i hv set the particle size to 30 in ocean foam settings Quote Link to comment Share on other sites More sharing options...
StepbyStepVFX Posted April 7, 2018 Share Posted April 7, 2018 (edited) Well, if the RAM usage doesn’t reach 100% just before it crashed, then it is probably another problem :-) Edited April 7, 2018 by StepbyStepVFX Quote Link to comment Share on other sites More sharing options...
