Instance Packed objects
breadbox
I'm trying to create a voronoii fractured geo to make rocks that will instance onto scatter points.
when I pack the object it will make a path attribute for each chunk something like this:
op:/obj/debris/assemble1/pack/piece0
op:/obj/debris/assemble1/pack/piece1
etc.
Is there a way to read those objects back in on an Instance SOP using scattered points on a grid?
I have tried using a point wrangle to create the s@instancepath attribute variable... but I'm not able to get it to work right.
I'd love to have a way to keep it as a live network and reference a packed object in an op:string.  I'm on a really complicated network where the path variables are out of my control and produce very complicated string paths if I write out files.
