samvac Posted April 10, 2018 Share Posted April 10, 2018 Hey There, Hope this message finds you well. I'm after a bit of help in regards to flip fluid interaction, I want two different flip objects to be able to interact with each other, within the same solver. this is what i have already. I can achieve interaction by combing the points within the same flip object, but i need to bee able to mesh each flip object separably. any help would be most appreciated TEST_BUUBLE_02.hiplc Quote Link to comment Share on other sites More sharing options...
bunker Posted April 11, 2018 Share Posted April 11, 2018 (edited) you only need one flip object and separate the 2 different fluids with an attribute for example. you'll need to add this attribute in the reseeding/interpolate attributes. have a look at the attached file. TEST_BUUBLE_02.hipnc Edited April 11, 2018 by bunker Quote Link to comment Share on other sites More sharing options...
samvac Posted April 11, 2018 Author Share Posted April 11, 2018 Thanks for the reply, really helpful !! Nice 1 Quote Link to comment Share on other sites More sharing options...
