Atom Posted April 11, 2018 Share Posted April 11, 2018 I am trying to export UVs from an object into a new file format. I can't seem to find out how to walk the data set to get the UVs exported correctly? I have geo = node.geometry() print dir(geo) So I can see some of the options contained within the geometry object but how do I access the UV coordinates for each vertex? Quote Link to comment Share on other sites More sharing options...
Atom Posted April 11, 2018 Author Share Posted April 11, 2018 (edited) I think I have found a way to get to the UV data but I am not sure how to package it up so it is convenient for the process that will read this data... node = hou.pwd() geo = node.geometry() # Add code to modify contents of geo. # Use drop down menu to select examples. for (i,prim) in enumerate(geo.prims()): if i < 4: # Just print out 4. print len(prim.vertices()) for v in prim.vertices(): print i,v.attribValue("uv") Edited April 11, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
