lisux Posted October 25, 2005 Share Posted October 25, 2005 Hi list, i want to generate deep shadows from a mantra ROP. I know i can generate Depth Shadow Maps using the -Z or -z parameters for the mantra command, but what about Deep Shadows, is possible to render them from a Mantra ROP? Thanks Quote Link to comment Share on other sites More sharing options...
Jason Posted October 26, 2005 Share Posted October 26, 2005 lisux said: Hi list, i want to generate deep shadows from a mantra ROP.I know i can generate Depth Shadow Maps using the -Z or -z parameters for the mantra command, but what about Deep Shadows, is possible to render them from a Mantra ROP? Thanks 22126[/snapback] I asked this recently and I'm afraid there is no direct support for rendering deepshadows directly from the camera view -as in a -Z or something. I believe you may have to place a light at the camera position and generate it this way. Quote Link to comment Share on other sites More sharing options...
lisux Posted October 26, 2005 Author Share Posted October 26, 2005 Jason said: I asked this recently and I'm afraid there is no direct support for rendering deepshadows directly from the camera view -as in a -Z or something. I believe you may have to place a light at the camera position and generate it this way. 22128[/snapback] See this Jason: http://www.sidefx.com/index.php?option=com...c&p=21658#21658 Yes, at the moment there aren't any way to generate deep shadows from a Mantra ROP. At the moment the best solution i use is to create a Mantra ROP that dont render anyting, only force light to generate their shadow maps. Hopefully SESI can add an option to render deep shadows from the Mantra ROP in future releases. Quote Link to comment Share on other sites More sharing options...
