Boolean shatter
AntoineSfx
Trying to replicate https://www.sidefx.com/tutorials/boolean-shatter/
What kind of geometry is expected for the input A ? When A is a box, I have a working setup by marking abseams in shatter then polybevel that abseams group.
When A is something else, like a polyextruded curve, I have a bevel between the two surfaces, and the two surfaces are in the output geometry.
Can you give me an example of a box being used to draw a groove on a polyextruded surface ?
  • 2 weeks later...
The object you want to cut or Boolean goes into A, so unless you want to Boolean a curve, the curve should probably go into the second input B. I included two examples in the hip file, one is cutting a box shape out of another box, the other is cutting a curve out of a box. Is this the kinda of effect you were after?
tutorial.hipnc
