Attribute Transfer Primitive Uvs To Point Uvs
mauchi
Here's an attribute transfer question:
I have a deforming poly mesh, I've scattered points on the surface. I'd like to transfer the primitive uvs of the deforming object onto the scattered points so that I can copy geometry onto the points with the z pointing like the faces point. What I get by default is a transfer of the point uvs to the new points which don't always point the same way as the primitive.
Thanks!
Mchi
Oops, I was a little fried when I posted this, I meant primitive and point normals, not uvs.
My goal is to scatter a bunch of points and when geometry is copied to those, they'll be aligned to the faces from the original mesh, like buttons on a shirt. The normals that come in with the scatter don't give me that result. Here's a scene
Thanks!
Mchi
normals.zip
