Save Custom Panel Externally
Hi Everybody,
I am creating a custom panel to add my own scripts to it. It is very useful, but I don't know how to save the panel externally in a file.
I know there is one option called "save panel to Hip", and i tested it by turning it off. But the panel remains only in the current sesssion. If i restart Houdini, it goes off.
Or is there a method by which i can create the panel thru Script and run that script whenever i start Houdini.
Plz tell me more.
Thanking in advance.
.............. Iamjaideep80
Hi grasshopper,
Your trick worked! Thank u very much.
I copied the cui file to custom folder and now I can load my custom panel evry time Houdini starts. But I don't know why there is no interface for loading and saving custom panels. But as far as it is working, No Probs.
But, can u tell me, if it is a custom panel, "Idealy" ,it should be loaded from user pref folder, that is $HOME. Can we change the path?
Any way, Thanks again.
-------- iamjaideep80
