Lukich Posted December 9, 2005 Share Posted December 9, 2005 Hi. I'm trying to render out a 32-bit targa. I understand that it's set in the Deep raster parameter of Mantra, but it only gives me access to 8 and 16-bit, plus a floating point. How do I set it to be 32-bit? Is it possible? Thanks, Luka Quote Link to comment Share on other sites More sharing options...
edward Posted December 9, 2005 Share Posted December 9, 2005 I don't think there's such a thing as 32 bit per plane targa's. I think you mean 8 bit per component targa's that have RGBA components which gives your 32 bit per pixel. In Houdini, the number of bits refer to per component. so an 8 bit image means it has 8 bit's per plane which is 32 bits per RGBA pixel. A 16 bit image means it has 16 bits per plane which is a 64 bit per RGBA pixel, etc. Quote Link to comment Share on other sites More sharing options...
Lukich Posted December 9, 2005 Author Share Posted December 9, 2005 I see. Thanks a lot, Edward. Quote Link to comment Share on other sites More sharing options...
Lukich Posted December 9, 2005 Author Share Posted December 9, 2005 I have another small question. Is there a minimum size to a targa file? I alway thouht that they don't get smaller then 1.2 MB. However, I have rendered a sequence with the default mantra settings, except for teh size (set it to 720 by 480) and the targa size is somewhere around 100 KB. The picture looks fine, though. A lot of area is an alpha channel though - can this be the reason for a small file size? tank_texture_lights_v1.127.rar Quote Link to comment Share on other sites More sharing options...
sibarrick Posted December 9, 2005 Share Posted December 9, 2005 I think the tga format uses run length encoding, a simple but sometimes effect method of lossless compression. If you have a large frame with not much in it the file size could easily get down to 100kb. Quote Link to comment Share on other sites More sharing options...
Lukich Posted December 9, 2005 Author Share Posted December 9, 2005 Thank you. Quote Link to comment Share on other sites More sharing options...
