Dr. Gore Posted December 20, 2005 Share Posted December 20, 2005 Can it be done? I want to use pops with character animation in Softimage. Quote Link to comment Share on other sites More sharing options...
edward Posted December 20, 2005 Share Posted December 20, 2005 Well, one can easily export points as .obj files. So if you could figure out how to get XSI to import sequences of points only .obj files ... Quote Link to comment Share on other sites More sharing options...
Alexander Weide Posted August 16, 2006 Share Posted August 16, 2006 I have to say, its the hard way. The best way you look to a plugin , wich you can use with nextlimits realflow. these plugins are free. the best is, you can export and import particle data between any software, i use this pipeline between houdini and maya. it works very well. try it......... Quote Link to comment Share on other sites More sharing options...
