Macro Dialog Ui Doubts
lisux
Hi all.
I am making some macro scripts to be called from the network editor context menu.
While making the dialog script, I have seen that the name and default statements must point to the same name or the dialog is not correctly loaded.
For example if i use:
name macro/ModelingAid.cmd
	label "Modeling Aid"
	default "macro/ModelingAid.cmd"
All works fine, but if i use these lines:
	default "macro/ModelingAid2.cmd"
The script dialog still call to the macro/ModelingAid.cmd script not to macro/ModelingAid2.cmd.
Another problem is that i want to call to this script with an option parameter by default, i have tried:
	default "macro/ModelingAid.cmd -p"
And obviusly doesn't work, i have to use:
name macro/ModelingAid.cmd -p
I get an error while trying to load the dialog script:
pablo@casiopea:~$ /home/pablo/houdini8.0/config/Scripts/SOPmacro.ds Error(18): script unknown identifier -p
/home/pablo/houdini8.0/config/Scripts/SOPmacro.ds Error(27): script unknown identifier type
So i have to use a param statement.
So how can I call to my script with the -p option by default?
How the default statement work?
Sorry for the large message.
Thanks
