Mauricio Posted February 5, 2006 Share Posted February 5, 2006 Hi guys, I wonder if anyone could help..I have just started to research into the HDK, I am setting up my environment but it seems not to be working. I set up the environmental variable MSVCDir as D:\Visual_Studio .NET_2003\Vc7\include , but when I try to compile some of the sample code in the /toolkit/samples by running hcustom, it returns an error saying that the variable is not pointing to the correct include directory ?????? wha..h ?????? I had a lok at the .NET istallation and this seems to me the only valid include directory.. For the love of god .... HHHHHHHHEEEEEEEEEEEEEEEEEEEEELLLLLLLLLLLLLLLLLLLLLLLLLPPPPPPPPPPPP Sincerely yours, Mauricio. Quote Link to comment Share on other sites More sharing options...
edward Posted February 5, 2006 Share Posted February 5, 2006 Try reading this page first: http://www.odforce.net/wiki/index.php/HDKF...yAskedQuestions Off the top of my head, I think it might be just using forward slashes instead of back slashes. Quote Link to comment Share on other sites More sharing options...
George Posted February 6, 2006 Share Posted February 6, 2006 I set up the environmental variable MSVCDir as D:\Visual_Studio .NET_2003\Vc7\include , 24438[/snapback] I think MSVCDir has to be set to the root of your MSVC install. Do you have $TOOLROOT defined? I think it should be set to the same thing... if not try setting it to just D:/Visual_Studio .NET_2003/Vc7 (without the include). George. Quote Link to comment Share on other sites More sharing options...
Mauricio Posted February 6, 2006 Author Share Posted February 6, 2006 Thank you For your advice guys, the variable has to point to the root of MSVC installation, it is working now. I'll let you know how I get on.. Cheers.. Quote Link to comment Share on other sites More sharing options...
Mauricio Posted February 6, 2006 Author Share Posted February 6, 2006 Hi There..it is me again...I got the environment to work, (Thank you again for suggestions) ,now when I try to compile some of the sample_install.sh it gives me a stream of errors mainly related to syntax (errors) like missing ; before identifiers etc. I added an image of the erros ( in spanish, but the error numbers may guide you... hopefully.. I am sure it has to do with the compiler settings and I spect the code to be right...isn't it? Any suggestions?.. Thank you for your support. Quote Link to comment Share on other sites More sharing options...
Mauricio Posted February 6, 2006 Author Share Posted February 6, 2006 HELLO Guys... As Stephen Hawking once said: " ...I worked it out..." yes !! it is up,running and compiling...Rock'nroll baby... problem was :having set up the development environment ( compiler global variables), once I spawned the cygwin shell it automatically initialises the Houdini environment ( by using the snippet of code I found in http://www.odforce.net/wiki/index.php/HDKF...yAskedQuestions suggested by edward) my error was I was trying to compile by typing: hcustom sample-install.sh, but since the Houdini environment is already initialised all you need is to type: sample_install.sh and VOILA ......... it compiles happily ever after... Thanks for your help.. I am sure I will hassle you about all this in the future, don you worry... Cheers.. Mauricio. Quote Link to comment Share on other sites More sharing options...
