Leon Amion Posted February 10, 2006 Share Posted February 10, 2006 I did a search but didnt really find anything. It has probably been asked a couple of times but anyhoo... I have installed Houdini on a laptop and the license administrator seems to have created the server code based of my wireless network card Quote Link to comment Share on other sites More sharing options...
stevenong Posted February 10, 2006 Share Posted February 10, 2006 Are you unable to run Houdini when you're not using your wireless card? I believe you should still be able to. If you specified standalone mode when installing for the first time, it doesn't matter whether the wireless or ethernet card is active. Maybe try launching the License Administrator & set it to Standalone mode. I hope the above works. Cheers! steven Quote Link to comment Share on other sites More sharing options...
Mcronin Posted February 11, 2006 Share Posted February 11, 2006 If it's like a PCMIA card, he probably removes it, which would mean no Houdini for him, I think. If this is the case, just return the licenses and generate new ones with the card out of your laptop, and it should get the MAC of your built-in wired ethernet. Quote Link to comment Share on other sites More sharing options...
Leon Amion Posted February 13, 2006 Author Share Posted February 13, 2006 Hey guys. Thnx for the reply. It is a built in WLAN card and I was fiddling around with the hardware and also changing MAC adress so thats how I stumbled upon the issue. This is my solution. I installed two licenses one for the wireless and one for the other. Houdini seems to prioritize the wireless card. The problem there is that if I go to http://license.sidefx.com/get_nc_license.php while being online I get the server code from the WLAN card so I first have to deactivate it and let the license administrator look for the LAN card. I did not think of it first and its no problem really though it would be easier if I could redirect Houdini to allways use one specific card. cheers Quote Link to comment Share on other sites More sharing options...
