peliosis Posted February 15, 2006 Share Posted February 15, 2006 I created a digital asset in object level, it uses object transforms and consists of some pieces parented together. There are controls and everything is ok. Here comes the question: am I able to use copy sop on an object OTL? It is a window and I'd like to import it to sops and copy on some building, and stamp my attributes like open/close and others. Of course my controls get lost when I obj_merge "/obj/window/*" into sops. Is it possible or is there other way? Quote Link to comment Share on other sites More sharing options...
stu Posted February 15, 2006 Share Posted February 15, 2006 You might consider doing the opposite - instead of pulling the windows out of the OTL, try pullling a set of points into the window OTL to copy the windows onto. You could provide a top level geometry input upon which the windows will be copied to. Quote Link to comment Share on other sites More sharing options...
edward Posted February 15, 2006 Share Posted February 15, 2006 Are you looking for something like this? hda_stamp.hipnc Quote Link to comment Share on other sites More sharing options...
peliosis Posted February 15, 2006 Author Share Posted February 15, 2006 Thanks guys, Edward it's just that. Thanks for your example. I must have been very tired Quote Link to comment Share on other sites More sharing options...
