Mozzarino Posted April 19, 2018 Share Posted April 19, 2018 I was reading some comments on how the @dead attribute generated by particle streams changes to 1 in the subframe before being reaped by the solver. Is there anyway to access this attribute after the simulation? For example, if I wanted to create a static point in that same position as the particle that is going to die? By the way, the generated particles are not from a POP Network, but yes from a FLIP simulation. Quote Link to comment Share on other sites More sharing options...
