Quaternion questions
catchyid
using vex...
a) First Question
float angle = radians(90);
vector axis = {just random vector}
vector4 goalQuaternion = quaternion(angle,normalize(axis));
Question: IF angle == 0.0, then is this a valid quaternion? I don't want to spin, so I am setting angle to zero, however when I do that, I don't get any rotation?
b ) Second question
if I have two quaternions:
vector4 Q_Init, Q_Dest; {they get initialized correctly}
vector4 Q_Diff =  qmultiply(Q_Init,qinvert(Q_Dest); //difference between two quaternions
My question:If I want to interpolate from init to dest quaternions in 10 steps, how do I do that? meaning If I multiply Q_Init by Q_Diff I will jump at once, but I want to that in 10 steps instead, it's like dividing Q_Diff by "10"
Thanks
a) if the angle is 0, you will get identity quaternion {0,0,0,1} so no rotation
as the angle/axis notation defines quaternion as a rotation of angle degrees around the axis, if the angle is 0, then the rotation around given axis is 0 and hence no rotation
b)
vector4 Q_Init = eulertoquaternion(radians(chv("q0")), 0);
vector4 Q_Dest = eulertoquaternion(radians(chv("q1")), 0);
vector4 Q_Diff =  qmultiply(Q_Dest,qinvert(Q_Init)); // quaternion difference from Q_Init to Q_Dest
int nsteps = chi("nsteps");
Q_Diff = slerp({0,0,0,1},Q_Diff, 1.0/nsteps); // compute Q_Diff rotation for single step
p@orient = Q_Init;
for (int i=0;i<nsteps;i++){
    p@orient = qmultiply(Q_Diff, p@orient);
// after adding Q_Diff nsteps times to Q_Init p@orient will result in Q_Dest
  • Like 2
