younglegend Posted April 26, 2018 Share Posted April 26, 2018 (edited) Hello, Widening my houdini knowledge and getting to know crowds here. So I have an agent with multiple layers like, an agent holding a sword and shield, just a sword, holding nothing etc. with multiple running states. The crowd source randomizes everything which is great, but i have few running states where the shield and sword overlap because of the randomness. Is there a way to make a particular layer only use a particular state all the time? Or creating a new agent primitive for that is the only way to go? Thanks! Edited April 26, 2018 by younglegend Quote Link to comment Share on other sites More sharing options...
JP Shep Posted May 1, 2018 Share Posted May 1, 2018 (edited) By layer I'm assuming you mean agent? if so then yes there is, a user named Atom made a very useful tutorial for doing just that. https://www.sidefx.com/tutorials/crowd-based-relay-race/ Edited May 1, 2018 by JP Shep Quote Link to comment Share on other sites More sharing options...
younglegend Posted May 1, 2018 Author Share Posted May 1, 2018 (edited) 1 hour ago, JP Shep said: By layer I'm assuming you mean agent? if so then yes there is, a user named Atom made a very useful tutorial for doing just that. https://www.sidefx.com/tutorials/crowd-based-relay-race/ Thanks for sharing that interesting tutorial! But unfortunately it doesn't help my situation. By layer i meant different agent layers, In my case i have 3 agent layers sourcing from one agent. A layer holding a sword, a layer with shield and sword and a layer holding nothing. Edited May 1, 2018 by younglegend Quote Link to comment Share on other sites More sharing options...
JP Shep Posted May 1, 2018 Share Posted May 1, 2018 Have you checked out SideFX's crowds masterclass? that might have what you're looking for Quote Link to comment Share on other sites More sharing options...
cwhite Posted May 1, 2018 Share Posted May 1, 2018 If you need more precise control over how each agent's layer is selected, I'd just use the VEX setagentcurrentlayer() function. The Attribute Randomize SOP has a mode that is similar to the Crowd Source SOP's options (the Custom Discrete mode with Type set to String), which might be useful for doing the actual randomizatoin Quote Link to comment Share on other sites More sharing options...
cwhite Posted May 1, 2018 Share Posted May 1, 2018 1 minute ago, cwhite said: If you need more precise control over how each agent's layer is selected, I'd just use the VEX setagentcurrentlayer() function. The Attribute Randomize SOP has a mode that is similar to the Crowd Source SOP's options (the Custom Discrete mode with Type set to String), which might be useful for doing the actual randomizatoin I should also mention - the input points to the Crowd Source SOP can have point attributes like state, agentcurrentlayer, etc that will override the Crowd Source SOP's parameters 1 Quote Link to comment Share on other sites More sharing options...
younglegend Posted May 2, 2018 Author Share Posted May 2, 2018 20 hours ago, cwhite said: I should also mention - the input points to the Crowd Source SOP can have point attributes like state, agentcurrentlayer, etc that will override the Crowd Source SOP's parameters Oh yes, setagentcurrentlayer() and state is the one i'm looking for! Thank you! Quote Link to comment Share on other sites More sharing options...
