file SOP naming problem
daland
Hi all,
I am writing a little script that reads in a bunch of bgeos in file SOPs (and then does some other stuff)... I want the name of the file SOP to be the name of the .bgeo. using s foreach and everything works fine except for
the naming of the file SOP
The problem is that SOPs don't like to have those pesky periods in the name like " file.bgeo"
in UNIX I can strip off the extenion using :r
set name = file.bgeo
set stripname = $name:r
I am looking for a way to do this in the textport...
any ideas?
thanks,
david
thanks danteA!
your suggestion works except when I use a variable like $fname..
If I use test.bgeo in place of $fname it works...I think it is maybe a
syntax problem ...have tried using quotes, ticks, single quotes but can't
quite get the right combination....
any ideas?
basically this is how I am using it.
foreach J ( `system("ls /bgeo")`)
echo $J
set geoname = `substr($j,0,rindex($j,"."))`
echo $geoname
thanks,
david
